It is currently Sat Jun 21, 2025 12:47 am
PostPosted: Thu Jan 12, 2006 10:56 am
Sunburst
PostPosted: Thu Jan 12, 2006 11:00 am
or stain it dark as martin and gibson usually do.
also be a good idea to get a router speed controller to keep your temps under control. they are on special at harbor freight right now for about
$12.crazymanmichael38729.7931134259
PostPosted: Thu Jan 12, 2006 12:11 pm
I would find a piece of scrap try to scorch it in a similar way and wipe a little pottassium dichromate on it and see if that smooths it out.
(Be careful though... that stuff is highly toxic)
I like that much better than pigment on mahogany.
PostPosted: Thu Jan 12, 2006 1:10 pm
First name: R
Last Name: Coates
City: Selma
You could take a propane torch and scorch the rest of the mahagony... Maybe not, since it's all boxed up now, but hey it's a thought.
Brock;
What's the story on pottassium dichromate?RCoates38729.8831018519
PostPosted: Thu Jan 12, 2006 3:46 pm
I agree with crazyman- get a temp control, only spend some more and get a
variac. Much more accurate, efficient and elegant way to control heat, rpm,
etc.
-C
Freeborn Guitars
and home of BeauGuard©
PostPosted: Thu Jan 12, 2006 4:14 pm
   Hi
    I can send you a nice set of ebonized Mahogany. I have cooked a few sets and they balance out nicely once you stain and fill them.
      Next time ad a dash of white peper LOL.. 400 degrees for a minute or 2 isn't a big deal actually , but put the blanket on the top. Best place for it. You can control heat better that way.
    Keep a spray bottle handy and NEVER WALK AWAY FROM A BENDING MACHINE THAT IS TURNED ON !!!!
Blues Creek Guitars
PostPosted: Thu Jan 12, 2006 4:17 pm
Potassium Dichromate will darken mahogany. I am not exactly sure of the chemical process, but as I recall it reacts with the tannin in the wood.
It is a really great look on Mahogany though, very warm and dark.
PostPosted: Fri Jan 13, 2006 8:03 am
I'm with brock here. you could use some spray oven cleaner on a rag It will darken the mahogany as well. use vinager to nutralize the solution when happy with the color because it will contiue to darken very dark if left active. Wash was with naptha after. Normally I would not try this on a box that has the top in place, but you could shellac the top end grain and top surface to protect them.MichaelP38730.67
PostPosted: Fri Jan 13, 2006 8:15 am
Michael, is Easyoff oven cleaner Potassium Dichromate in a can?
Sorry for my ignorance, but I to burnt the heck out of a nice set of mahogany.
Id love to save it if possible.
PostPosted: Fri Jan 13, 2006 9:53 am
[QUOTE=LanceK] Michael, is Easyoff oven cleaner Potassium Dichromate in a can?
Id love to save it if possible. [/QUOTE]
I dont't know???? I will check tonight but I think it does contain some.
PostPosted: Fri Jan 13, 2006 10:02 am
I got some at a paint and finish store. I think you can find it pretty easily.
PostPosted: Fri Jan 13, 2006 12:40 pm
Terry, for what slim comfort this might give, your side looks fine from way down here in Texas.
I agree with CrazyManMichael that a stain is the way to go, and it looks like it won't take much of that to blend things out nicely.
Give us some after shots when you fix it!
PostPosted: Fri Jan 13, 2006 10:14 pm
I agree with with Steve, I have hidden a lot worse boo-boos under some stain or dye...
